04-24-2005, 10:46 AM
Hone rough cylinder?
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
I melted a piston. I removed some melted aluminum from my cylinder wall and checked the bore size. The cylinder is OK dimensions-wise, but where the aluminum was bonded there is some texture, like fine sandpaper, to the cylinder. Can that be honed out if the bore size is still OK, or should I leave it be?
04-24-2005, 02:09 PM
Engine: 2.5 turbo
Thanks, I didn't know the lye trick.
04-24-2005, 02:42 PM
Originally Posted by lametec
Are you sure you got all the melted aluminum off?
I used lye (Red Devil brand) mixed with a bit of water to remove the aluminum from my cylinder wall. Apply with a q-tip or something, then let sit for a while (hours). Repeat a few times 'til all the aluminum is gone.
The lye won't hurt the block.
If you got all the aluminum off, then yeah, you'll have to hone it. You'll ruin your rings if you don't.
Thats awesome, good tip!
When I melted a piston, it actually scored the wall so after you get the aluminum off, make sure the bore isn't scored.
Use a ball hone also, I have found that the bar type hones suck!
04-24-2005, 04:14 PM
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
dittos...
the only reason to use the bar hones is if the bore isn't square (or close enough), which at that point you should bore, not just hone...
Check your bore sizes, and clean up that bore. Take measurements and then order the right piston for the hole - there were 3 different 'factory' sizes that they used to allow for slop in the manufacture...
04-24-2005, 04:20 PM
Originally Posted by Phreakish
dittos...
I think he's looking for some forged???
But I know what you mean about the diff sizes, lol!
04-24-2005, 04:44 PM
Originally Posted by bmxrider
didnt you read the hanyes manual yet? they use a ball hone to honed the cyclinder wall.
Dude, I have been doing this since the mid 80's. Nobody had ball hones then, just bar type hones. They do work but the ball hones are much better.
04-24-2005, 06:15 PM
Engine: 2.2 Turbo
the acid is easy to find, its usually in the back of the hardware store - not on the shelf because its 'hazardous'...
Hydrochloric is great, eats rust, leaves it CLEAN, and will dissolve nonferrous metals... mm-mm, tastes good too! little spicy, but hey... LOL.
Turbovanman: yup, I know whatcha mean too. I tried getting 'stock' sized pistons. Then went and found out about ABC pistons... yeah, I had 1 C, 2B's and 1 unmarked, in an engine that had been redone by a moron... So I just got som +.030's they didn't fit in any of the bores, so that was good  Then had the shop bore to the pistons and now have a really nice engine... $1200 later, but hey, its worth it to have a GOOD engine... and now I've just gotta get the crank finished up, balanced, and then have some REAL fun
04-24-2005, 11:56 PM
#14
Engine: 2.5 turbo
dittos...
So, if I want to get rid of slight irregularities in the cylinder wall from removing the aluminum, it might be better to use a bar hone?
