04-29-2005, 09:14 PM
My Ride: TIII R/T
Engine: 2.2L TURBO III
yes, it will fit i have heard
04-29-2005, 09:35 PM
My Ride: 88 Shadow
^Yup, it's longer because that the pan holds a quart more oil.
04-29-2005, 09:45 PM
My Ride: 88 Shadow
Dude just re-read mine and daniels posts, he said you need the 2.5 dipstick and I said you'll need to run the extra quart.
04-29-2005, 11:22 PM
Don't forget the oil pump pickup, its shorter on a 2.2L. If you don't run the 2.5 pu, you will get oil starvation on minor cornering or braking!
04-30-2005, 02:28 AM
My Ride: GLH-T
very good point mr.8000 posts lol.
04-30-2005, 03:13 AM
Why thankyou,
hehhehe
make that 8001!
04-30-2005, 03:44 AM
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
Good ones too!  The life and vibrancy of the board depends on people contributing to the threads
04-30-2005, 12:45 PM
#12
My Ride: 2004 SRT4
Engine: 2.4
It won't. Just use the 2.5 pick up. You'll have an additional quart of capacity if you took out the balance shafts. You'd also need a windage tray.
05-07-2005, 01:52 PM
#13
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
I built up my 2.5 motor and put a 2.2 dipstick, pickup and oil pan on it. I think running a 2.2 pan is better. The 2.5 pan is too deep, oil sloshes around more and is more prone to oil starvation with out some baffles (etc). A 2.2 pan is better as it doesn't slosh around the oil as much, better ground clearance as well. Dipstick tubes are the same (just 2.5 dipsticks are longer). And oil pickups are very important. 2.2 pickup with 2.2 pan and 2.5 pickup with 2.5 pan and you're set. Good luck.
