05-01-2005, 02:58 AM
4-bolt mains
I was looking a the internals of the 2.5 I have on the engine stand and I noticed that with the holes from the ballance shaft assembly, it would be rather easy to run 4-bolt mains. You'd still have to drill and tap holes for the #4 main cap, but the biggest problem I see with running 4-bolt mains is that cover thingy on the back of the engine where the flywheel mates to the crankshaft (is that thing called the rear main seal?). It only has enough room to cover the stock 2-bolt main cap. You'd have to fabricate another cover thingy or mod the stock one to cover the new 4-bolt main. Same thing goes for the oil pan, since it mates to the block there.
I realize that on a common block the mains are already pretty damn strong, and that it would probably be easier to run ARP main studs and billet caps if I was really concerned about it. But with some of the power guys with hybrids are making, I am starting to wonder just how much more power can be had with a common block before you get twisting in the mains, like Gary describes at www.thedodgegarge.com, even with unequal lenght axles. This is purely hypothetical, unless someone out there has experce in this situation (making BIG power, craking blocks, etc).
Would anyone like to weigh in on this?
