Old 05-03-2005, 11:16 AM   #1
Exclamation Dumbest question yet?
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
OK, go ahead and blast me for his one; I fully expect it. Having wet sanded with water many times and getting a great finish, I wonder why we couldn't hone cylinders using water instead of oil or dry?
John B is offline
Old 05-03-2005, 11:20 AM   #2
My Ride: 98 acr neon 2dr
Water + cast iron = RUST
klee is offline
Old 05-03-2005, 11:23 AM   #3
My Ride: 89 Daytona Shelby
honing produces alot of heat. oil is used to carry away the heat and the particles of metal so your cylinders dont glaze. and rust sucks
Mr. Stroker is offline
Old 05-03-2005, 12:15 PM   #4
Engine: 2.5 turbo
Thanks, I needed that
John B is offline
Old 05-03-2005, 03:13 PM   #5
Smile
Engine: 2.5 turbo
To be the contrarian here, when we finish honing we wash the bore with soap and water. Of course we don't leave it like that for it to rust away, we coat it with oil. Why couldn't the same thing be done after honing with water?
John B is offline
Old 05-03-2005, 05:17 PM   #6
My Ride: 84 rampage
Engine: 2.2L T3
the honing process is not meant to leave a perfectly smooth finish. it is meant to have a rougher crosshatch to enable proper ring seating. oil is friendly to the tooling and, yes, does not rust.
Mike Radowski is offline
Old 05-03-2005, 05:40 PM   #7
My Ride: 88 Shadow
Feedback: (7)
Clickhere33 is correct.
moparzrule is offline
Old 05-04-2005, 04:07 AM   #8
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
Another point is the oil helps flush the stones and keep them from clogging up. Sunnen even makes their own oil just for this. It's different than motor oil, it's more like a cutting oil.
Andre Parker is offline
Old 05-04-2005, 05:10 PM   #9
My Ride: 88 Shadow
Feedback: (7)
Yup, it's called honing oil LOL. WD-40 or standard motor oil works fine though.
Old 05-04-2005, 07:05 PM   #10
We use a mixture of water and oil when honing. We have found it to leave the best results in the cylinders when done.
ombomb is offline
Old 05-04-2005, 11:03 PM   #11
Engine: 2.5 turbo
How do you feel about dry honing? I dry-honed cylinders for years before I heard about honing oil. It's amusing that what worked fine years ago is now considered herecy
John B is offline
Old 05-05-2005, 07:12 AM   #12
My Ride: 88 Shadow
Feedback: (7)
Did you use a bottle hone or the hone with 3 long stones on it?
Old 05-05-2005, 08:25 AM   #13
Engine: 2.5 turbo
I use a Lisle 15000 micrometer head to rough size the bore and then a 320 flex hone to plateau hone. I know many feel that 320 is too fine, but that's a whole different issue.
John B is offline
Old 05-06-2005, 02:12 AM   #14
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
I've always used Sunnen machines. Never had a problem.
Old 05-11-2005, 01:07 PM   #15
Engine: 2.5 turbo
Excellent hone. I wanted a Sunnen but the cost was out of my reach. The Lisle does a good job too.
John B is offline
Loans | Mortgages | Car Loan | Free Ringtones | Loans
Page generated in 0.43205 seconds with 13 queries
