07-25-2005, 06:20 PM
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
You can use a non-turbo cb. I can get those at a rate of about 3 per day around here, just not the turbo blocks. What I do is drill a hole in the block for the oil drain, tap it for 1/2" NPT threads, then chuck up a piece of 5" X 1/2" NPT pipe and cut off about 3/4" off the end and cut a nice hose nipple on it. Granted, I have a mill-n-drill and lathe, but that's the only difference between the turbo and non-turbo blocks (until you get into TII-TIII-TIV blocks that are cross drilled). Your friendly neighborhood machine shop should be able to handle that chore for you. (Oh, it's a 23 degree angle on the pipe.) The non-turbo blocks are even drilled and tapped for your coolant line (behind the ps pump).
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
08-10-2005, 05:28 PM
89 cb
My Ride: 1991 Daytona Iroc HT
Engine: 2.5 intercooled
you can also snag a turbo common block out of any 89+ 2.5t1 personally id look for a 90 or newer 2.5t1 motor. they are all over the place.
same block, same rods. just a different crank and pistons.
if you cant find one and you need it badly pm me. i have several.
08-10-2005, 09:46 PM
Engine: 2.2 TIII
Too bad you don't live closer. I can get you free or cheap blocks galore around here.
mpgmike
'88 Daytona Shelby
'91 Spirit R/T
'84 Rampage
'89 Masi TC
08-11-2005, 09:33 AM
#13
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
dont get a 89 CB if at all possible. the 90 and newer is what you want. In 90 beefed the rear of the block to prevent this cracking that is prevalent in high HP cars. I used a TBI block and routed the drain to the oilpan.  works well.
Brian
09-05-2005, 12:19 PM
#14
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
"High HP cars"... At what WHP point do the '89 common blocks start to have crack problems? And how can I tell for sure that a 90-up CB has the extra reinforcements? Got photos?
09-05-2005, 12:48 PM
#15
My Ride: '87 Lebaron Coupe
Engine: mild 2.2 TII
Originally Posted by 84TurboZxt
I have been needing a to get a 2.2 short block for a build up, but have not been so lucky to even find one in good shape. Well I did get one 2.2 out of a 88 sundnace that looked good, I was so happy to think my car could be back on the road. Well here is the bad news, after taking the turbo off I find it has a 5 inch crack in the middle of the block. Now I am so bummed! I can take it back and get my money back before 30 days, besides the $40 in gas it took me for the round trip there and the $40 to do it again. It was the only engine they had ther beside one that had been on fire. my ? is.. has anyone ever welded a thin crack to keep it from spreading? and do you think there would be any problem with a block that was in a fire? thanks if I can't find a good block cheap...... I am getting out of TD forever, this is getting insane try to find good parts!!!!
Did you go to Pull-N-Save on Peoria and I-70?
