07-29-2005, 12:15 PM
My Ride: GLHS Charger
The cast mahle are fine but what happens if you want to increase the boost/hp at a later date. Do you want to open it back up? J.E.'s are my pick, hold up great, light and have great tolerances. There are others but that is for you to decide. Check for extreme shaft play on the turbo and make sure the wheel isn't hitting the outside housing. If it is, it's toast. Do you know the mileage on the motor? I would get them to resize the rods w/ good rod bolts if you haven't already done that. Good luck.
07-29-2005, 02:39 PM
Engine: 135 CI
Originally Posted by flowman759
Thanks for the quick reply. Where's the cheapest place to find J.E's? I'm not sure what the mileage was on the motor. Turbo seems to be good, minimal shaft play. I had them go 10 over on the rods, but I didn't change out the studs....ARP?
This motor is going in my '88 Lebaron Turbo Coupe with an A520. Do I need to replace any transmission parts? Upgraded clutch?
Sorry for the newbie rebuild questions. I love the TD's but this is my first rebuild.
James
'04 SRT-4
J & E's are available through Forward Motion Inc.
Other pistons available are:
Venolia's (Through FWD Performance and Turbos Unleashed)
Weiseco's (Through Turbos Unleashed)
Diamond (Through TurboDynamx)
07-29-2005, 07:07 PM
So far, I vote for JE's, there so quiet, even when stone cold and they definately look beefy, only time will tell,
08-08-2005, 12:18 PM
The 2.2 pistons are less prone to cracking under detonation so if you get the tune right, you should be ok. As for the rod bolts, you will have to have them resized.
08-08-2005, 03:29 PM
Oh, so Forged pistons are recommeded more for the 2.5L motors than the 2.2's? Maybe I'll just stick with the stock rod bolts if I'm going to have to resize them again for the ARP bolts (I'd like to avoid doing that).
the stock rod bolts are pretty much throw-away's after 2-3 tourque cyles.
they should be fine for your goals.....but again, you may get the boost bug and look for more later  i always use the arp's
mahles should be fine, granted you have a proper tune. just have a efficient i/c and proper gauges.
on forged pistons...im set on wiseco's  plus you can get them in near the stock wrist pin size, just needs a lite hone.
and the tranny should be fine, but its a great time to change the clutch. a t2/t3 clutch will work wonders.
oh, and i definitly recomend a tourque plate.
just my .02$
08-08-2005, 10:47 PM
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
PLEEEZZZE get the ARP rod bolts. That is the single biggest weak spot in the 2.2/2.5s I've torn apart! The Mahles are pretty decent. If you'd like, I could put a thermal coating on them for $7.50 each (+Shipping). This will help them live longer at a cheaper-than-forged price.
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
'89 Masi TC
