07-29-2005, 10:46 PM
Make sure the journal and bearing halfs are clean of oil. Put the bearing in the rod end of course. Break a little plastiguage off, aprox 1/2 inch and lay on rod cap with bearing installed. Carefully lift up and install rod cap. Torque to spec and DON'T MOVE the crank when tightening. After thats done, undo rod cap and remove. You will see the PG has been squished. Use the handy dandy measuring tape on the package. You should be around .001-.003" If its less or more, you should try another bearing, mix and match and make sure you have the right size bearings. If that checks out, the crank needs machining and/or rod resizing.
