08-01-2005, 09:29 PM
Old School Hot Rodder
My Ride: 1985 LeBaron Vert
Engine: MOPAR 2.2L
You can do it in place, but it's a bear. I had to do the inner bearing on a 2.5 that had gone bad. I used a tap to thread the old bearing and pull it out. Lined up the new one and used a bushing driver to put it in.
Bill Vose
1986 Turismo 2.2 (race car)
1986 LeBaron convertible 2.2L TBI (dead)
1986 F350 Crew Cab DRW
1993 Grand Caravan 3.3L
08-01-2005, 09:54 PM
what about the shavings that would have gone into the engine? how long of a tap did your use? that's like 8" in and what did you used to pull? they are pressed in pretty solid.
I have the bushing driver forsale ( generic cam bearing installation tool with the special 2.2/2.5 only inter. bearing installer)
08-01-2005, 11:11 PM
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
they BOTh stripped? wtf? how?
08-02-2005, 01:13 PM
Bad pump, talk to Dave! Also what 22Dodge mentioned. Another thing to remember is alot of these engines have tons of miles. You have a slightly worn shaft, then plop on a new or different oil pump, the wear patterns are now different and can accelerate the old wear, next thing, its worn out. This used to happen on the old 78 Civics. The oil pump was driven by a gear on the cam, I put a regrind in my car, a month later, no oil pressure-WTF? Cam gear was gone. Honda had a redesigned gear, another cam, new gear, problem solved!
08-02-2005, 01:18 PM
My Ride: 1991 Daytona Shelby
Engine: 2.5L
Originally Posted by 3.0Duster
my intermediate shaft gear and oil pump gear stripped again after 3 months, broke some teeth to
i have a similar issue on my fresh block. as you rotate the intermediate shaft, the play in the oil pump gear changes. i jumped some teeth at SDAC-15. I dont know whether it is because of crappy oil pump gear or an intermediate shaft. both will get replaced this coming winter.
frank
08-02-2005, 10:25 PM
#13
If the mains are like that, I am scared to see what the rods are like,
They take the most abuse and get the oil later, after the mains. Its not uncommon to have bad rods and good mains. Check ALL the rods. If they are bad, then it really doesn't matter. If there good, and the main bearings aren;t showing a copper colour, then go for it and see what happens!
