08-02-2005, 08:14 PM
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
While you have it apart, head porting is money well spent (or time well spent if you decide to do it yourself). Time and again it has been pointed out that our biggest "weak link" is the head. Several posts here on doing your own porting.
-Use a stock 4-bolt oil pump. Don't be tempted to go with one of those Mellings etal. high pressure jobbies.
-Before you tank your block, match the hole in the block (round stock) with the hole in the oil pump (oval). This not only adds 8 HP (according to one of Mopar's top engineers on the 2.2 racing program), but also improves oiling system.
-Snipping every other water pump blade (3 total) adds another 3 HP w/o sacrificing cooling system efficiency.
-When you get your block done, have it decked (they raise around the head bolt holes) and get it bored with a torque plate. Our engines are ones that distort significantly when the head is torqued in place.
-'89+ 2.5 turbos already have good rods. Get ARP bolts in them and then have them resized (big end). Replace the factory bushing (small end) with a genuine brass bushing. Factory bushings are brass plated steel (not as good).
-depending on what you mean by "alllot of boost", consider ARP head and main studs, too. Factory stuff is good to (I seem to recall) about 275-300 HP. Above that, ARP.
-While you have your oil pick-up tube removed, enlarge the hole at the big end for easier scavenging.
-A baffled oil pan will give noticedable HP increaces at upper RPMs. Buy or build one.
Depending on how much you do yourself, you should easily be under $1 grand (US).
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
