08-04-2005, 02:34 PM
Show me your g-valve
My Ride: '89Baron, '04Stratus
Originally Posted by iTurbo
Nope, no PCV system. I just have a heater hose clamped onto the valve cover PCV port which goes to a 20oz water bottle as a catch can. After 250 highway miles, the bottle is about 1/2 full.
There is oil collecting inside my intercooler and pipes, yet the turbocharger doesn't seem to have any shaft play.
WOW....that is some blow by.....but if your pcv dydtem isnt connected to your intake track or your intercooler tubes, its got no way to get into the turbo.....is your oil return line clogged at all, if it is it can force oil past the seals in the turbo even if your shaft play is good...you get shaft play from a bad bearing, not bad seals if i understand it correctly..
