Old 08-04-2005, 11:11 PM   #1
2.2l NA block
My Ride: 1985 Glh-T Omni
I have an 1989 NA 2.2L out of an omni. would this be a good block to make into a turbo engine TII?
If so what does it have going for it, and what internals might have to be changed?
85glhomni is offline
Old 08-05-2005, 12:37 AM   #2
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
common blocks were available from 89+ strongest of them all. and yes, they're good for the T2 since they used the same block.
T2 still keeping the 2.2 or upping to 2.5L?
you'll need everything BUT the block from a T2 vehicle. pistons, rods, crank, head, manifolds, turbo, intercooloer, etc...
and alot of research.
bluneon is offline
Old 08-05-2005, 12:39 AM   #3
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Yeah, good block. You can even use the crank, it saves on weight. I built a real nice engine that's got a cast 2.2 crank in it for my GLHS. Planning to make about 350whp with it..
Una is offline
Old 08-06-2005, 11:20 PM   #4
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Like BLUNEON said, use internals out of a turbo engine. You could get away with TI rods, but TII rods are recommended. Turbo pistons should be used as well, though some guys are using TBI pistons for better off-boost torque. Since it's an '89 block, you would need a crank out of an '89+ block, OR redrill the end of the block to accept the '88 older style seal housing (not easy and definately not for the neophyte). The N/A block has the port drilled and tapped for the coolant line, but doesn't have the oil return line from the turbo. I've converted them by drilling and tapping a 1/2" NPT hole at a 23' angle, then screwing in a piece of 1/2" NPT black pipe. If that scares you, you could rig up an oil drain tube in the top of the oil pan and just run longer hose. I'm in PA, which is a tad far to be of much hands-on help. Good Luck.
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
mpgmike is offline
Old 08-09-2005, 06:41 PM   #5
Thanks guys for your help
Vhs for sale | The eBay Song | Credit Cards | Car Loan | Myspace Layouts
Page generated in 0.35704 seconds with 13 queries
