08-10-2005, 09:42 PM
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Good luck trying to find 0.010" over pistons. The standard is a 0.020" oversized piston. Rod and crank are standard at the 0.010". I'd get the block decked to get it square and perfectly flat. I've found that they have raised spots around the head bolts, and low spots between the cylinders. Fewer head gasket problems that way. Align boring is a job that some blocks need and some do not. Your machine shop should be able to check to see if your block needs it. ARP rod bolts, recondition the rods to make the big end perfectly round (done when new rod bolts are pressed in), ARP main studs, and ARP head studs. I'm hoping you are using an '89 + block. They are much more durable than the '88 and older blocks. MP head gasket is your best choice.
While the block is apart, before you have the final tank cleaning, use a die grinder and oval out the block-to-oil pump hole in the block to match that of the oil pump. This frees upto 8 HP and improves the oiling system. Enlarge the hole in the pick-up tube so the oil pump doens't have to work as hard to suck up oil.
I perform a #4 coolant trick a little different than the one(s) in this site. I drill a hole in the freeze plug at the #4 end of the cylinder and weld in a 90' elbow of about 1/2" in diameter. I use the threaded hole on the top of the t-stat housing (or drill and tap one for heads that don't already have this hole) and install a 3/8" NPT X 1/2" flare 90' brass elbow. Next I connect the two dots with heater hose and 1/2" ss tubing.
That's about it for durability mods from my camp. Hope this helps.
mpgmike
'88 Daytona Shelby
'91 Spirit R/T
'84 Rampage
'89 Masi TC
