Old 08-09-2005, 12:51 AM   #1
Head Studs or bolts
Mr Overkill's Avatar
My Ride: 90 daytona shelby
Are head studs(ARP) better then the mp head bolts and why ??
just asking so i know planning to run 20 psi and wanna do it right
Mr Overkill is offline
Old 08-09-2005, 12:59 AM   #2
studs are better but more expensive. there are many threads on the "modifications" needed for studs (cutting/washers..)
they work better because the head of the bolt contacts the head and the threads dont turn as much (shaft of headbolt twists some) on headbolts. this dosent happen as much/at all with head studs. thus more even/precise clamping force.
daytonaer is offline
Old 08-09-2005, 01:07 AM   #3
Good answer but you have that backwards, the studs are fine but the bolts need double washers.
Dollar for dollar, studs are the way to go, better and more even clamping force and there reusable so if your like me and like experiment, you don't need to buy 10 sets of head bolts, lol!
Old 08-09-2005, 05:46 AM   #4
what if you only have one washer for each headbolt???
QKsilverF1 is offline
Old 08-09-2005, 07:21 AM   #5
Old School Hot Rodder
85lebaront2's Avatar
My Ride: 1985 LeBaron Vert
Engine: MOPAR 2.2L
What mods for studs? Mine went in fine and the newer ARP studs have an allen hole in the top for easy removal. Makes getting the head off just like useing bolts, take off the nuts, unscrew the studs and it will come off easily. That used to be the main objection to studs, the head had to be pulled straight up off them and reinstalled the same way. I just used the ARP washers and nuts.
Bill Vose
1986 Turismo 2.2 (race car)
1986 LeBaron convertible 2.2L TBI (dead)
1986 F350 Crew Cab DRW
1993 Grand Caravan 3.3L
85lebaront2 is offline
Old 08-09-2005, 12:08 PM   #6
Use reuse one of the original bolt washers but the MP's are fine, its the ARP's that are too long so you use 2 washers, no biggie.
Old 08-09-2005, 12:31 PM   #7
If I had the newer studs with the hex provision, I would go with studs, but geting the head out of my omni with the studs on made me want to kill whoever did not make the aforementioned provision. I am glad to hear that they are now coming that way.
OmniGuy123 is offline
Old 08-09-2005, 12:33 PM   #8
Yep, they call it "broached", they've been coming that way for a few years I believe. In my van, can't pull the head without removing them and its so easy, just use my cordless screwdriver with a allen bit on and zing them in and out,
Old 08-09-2005, 12:38 PM   #9
i will go with studs next time then, as the head bolts start to deflate the wallet over time!
Old 08-09-2005, 12:43 PM   #10
I would have spent $1000's on head bolts,
Old 08-09-2005, 01:09 PM   #11
My Ride: 1985 Shelby Charger
Engine: 2.2 turbo II
Anybody have problems with the studs fitting through the holes in a "G" casting cylinder head? I did. It really didn't make sense to me since the bolts/studs are the same thread pitch and the bolts went through no problem.
ShelbyGLHS592 is offline
Old 08-09-2005, 01:19 PM   #12
Most early G-heads had 10mm head bolts so the 11mm would be a tighter fit, just need to drill out the head bolt holes and problem will be solved!
Old 08-09-2005, 01:27 PM   #13
Yeah, but my 11mm head bolts slide through just fine. I was going to drill the holes out larger, but didn't have access to a drill press at the time.
Old 08-09-2005, 01:43 PM   #14
I think the studs are slightly larger. Don't need a drill press, just use a drill with a right drill bit!
Old 08-10-2005, 12:49 AM   #15
ok getting some good info
Ringtones | Debt Consolidation | Free Online Games | Bad Credit Loan | Cheap Loan
Page generated in 0.63705 seconds with 13 queries
