08-09-2005, 07:31 PM
Piston Cracked, HELP!!
Hi there, bought a 87 csx 1 month ago, drove it for two days but had lots of blowby in engine (Leaking oil everywhere)
compression
cylinder#1 140psi
cylinder#2 130psi
cylinder#3 130psi
cylinder#4 85psi
Now I took everything apart and found two cracks on cylinder #4 between the rings on the cyl, and when you removed the rings It was actually a chunk of the piston was broken off but being held in by the piston rings...
(Malie pistons)
OK GREAT!!!! I ordered 4 new pistons, rings and connecting rod bearings from ebay... They were clevite's...... Anyways I installed them (Did not bore out motor cause block in good shape) and the car ran good for about 3 - 4 days and then I started to get the blowby all back again (Oil stick keeps popping out)
compression
cylinder#1 130psi
cylinder#2 60psi
cylinder#3 130psi
cylinder#4 130psi
I took the motor back apart TODAY!! and removed piston # 2 ( PISTON IS ONLY BEEN IN CAR FOR 2 WEEKS) and It seems to be cracked in the SAME PLAce between the two rings and chunks of the piston feel apart in my hand, BUT NO DAMAGE TO CYLINDER WALL AT ALL!!!!!!!!
08-09-2005, 07:39 PM
Were the pistons brand new?
You have a detonation problem. How did you set your timing? what kind of boost? fuel grade used?
I just saw your other post-
Forged are a good idea but even they will still crack if you abuse them!
08-09-2005, 07:47 PM
My Ride: GLHS Charger
What computer are you using w/ the gm map sensor? Do you let the computer control the boost or do you use a grainer?
08-10-2005, 03:24 PM
How your running 20 psi on a stock fuel system is beyond me,
But yeah, you need to install some new pistons, TURN the boost down to say 14 psi, and go from there.
Have you read up on www.thedodgegarage.com ?
You need to upgrade your fuel system, computer before running over 15 psi.
08-10-2005, 03:39 PM
If you can get the numbers of the injectors, we can definatley see if they are +40's. Some cals are really aggressive on spark timing so that could be it also.
91 is way to low for 20 psi, if everything checks out, then you will have to run higher octane gas or lower boost.
I know you said CSX but is it a 2.2 or 2.5? A 2.5 could have been installed also?
08-10-2005, 03:44 PM
#12
My Ride: 91 Spirit R/T
Engine: TIII, 2.2
Check his second post he is running +40 injectors I think. The readings on the Auotmeter guage sound strange. I have this gauge to. My gauge is red lights = lean, yellow lights = good, and green lights = rich. I am all stock, and I have the second to last green light lite at WOT
08-10-2005, 03:48 PM
#15
Originally Posted by stephenrussell
So I believe the setup should be ok (maby need a bigger intercooler for 20psi boost im not sure)
If you run a motor too lean will that cause detonation (broken pistons) is this my problem ???? or is my problem maby too much boost and too high of a temperature?????
Sorry, missed that.
We need to make sure you have the corrrect injectors just to be sure. Lean will cause detonation that will shatter and melt pistons. Your intercooler if fine at 20 psi but doing the best job.
I would fix it, turn down the boost, get a scanner and monitor knock, then turn up the boost slowly. AGain, your octane is tooooooooo low for 20 psi. You need higher or home brew gas.
