Old 08-11-2005, 12:00 AM   #1
bad sounds
hi my name is ross and i am new to these p-body cars. i have a 91 shadow with a 2.5 NA and a 5sp. the engine is making some knocking/slapping noises and i was wondering how to tell what is making the noise...like if its piston slap.. i know how to check if its the rod bearings by wiggling the rods but how do i check piston slap and will i need to remove the engine from the car? thanks for all your guy's help
akshadow is offline
Old 08-11-2005, 08:33 PM   #2
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Use either a stethescope or a long screwdriver placed against your ear to try to isolate the noise. If the noise seems to be coming from the oil pan rail, then you're probably looking at connecting rod bearings. If the noise seems to be coming from the middle of the engine (head to oil pan/top to bottom), then it is probably cracked piston/piston slap. After you've entertained yourself doing these checks, add 2 bottles of STP Oil Treatment to the next oil change of 20w50 and drive it until you get serious about putting together another engine, or sell it.
I put 40k miles on my '89 TI 2.5 Daytona with a cracked piston and I couldn't blow it! I added an intercooler, upped the boost to 12.5, then used 89 octane middle grade fuel to see if it would blow. No such luck. I finally sold it because it was too durable. I guess I like rebuilding things LOL!
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
'89 Masi TC
mpgmike is offline
Xbox Mod Chip | Debt Consolidation | Credit Counseling | US Business Directory | Loans
Page generated in 0.43837 seconds with 13 queries
