Old 08-15-2005, 08:49 PM   #1
Piston Clearance ????
ok guys hope you can help me here with this (I am a air conditioning repair man not a mechanic) but anyways.....
I was trying to figure out what my clearance was between my cylinder wall and piston today on my 2.2L, because I wanted to know If I was near specs to install new forged pistons std size.....
When I measured the cylinder it was between 3.434" and 3.436"
When I measured the Piston (A new cast one standard size) I was getting say 3.438 and 3.440 measured at bottom of piston on the skirt...
Now I haven't honed the cylinders yet ( But I am going too )...
So when I take a average I think I have a Clearance of .004 " (3.439 - 3.435)
DOES THIS SOUND RIGHT??????? did I screw up???? What clearance should I be looking for say to install forged wisco pistons????
THANKS GUYS
stephenrussell is offline
Old 08-15-2005, 08:55 PM   #2
That looks about right. I think Wiseco's recommend .0045 so you'll be close. A good hone should clear that up. Did you check for taper?
Old 08-15-2005, 09:38 PM   #3
Question
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
THANKS GUYS
You say you have a piston that measures 3.438" going into a hole that measures 3.436"? Could it be that you have your numbers reversed?
mpgmike
'88 Shelby Daytona
'91 Spirit R/T
'84 Rampage
'89 Masi TC
mpgmike is offline
Old 08-15-2005, 09:49 PM   #4
I used my friends telescoping gauge i believe, and there didn't seem to be any warpage or anything like that and all cylinder walls look the same...so i would say no taper at all
Old 08-15-2005, 10:08 PM   #5
checked again cause ya that didn't make sence did it.....
seems to me (on my gauge) that piston is a tad bigger on the bottom than the top, but anyways bottom of piston is 3.439, and I took my telescoping gauge and checked the cylinder, And now I just measured that measurment 3.442 / 3.443..
so does that sound better,, cause 3.442 - 3.439 is 0.003
Old 08-15-2005, 10:18 PM   #6
Ya I must of screwed something up there, I think those were measurments from top of cylinder wall with the taper or whatever... But I did it again and I believe I got about a 0.003 clearance
I will check again later after i hone it, is that a good Idea???? If I hone it and Find out I got a clearance of over .004 will that be too much, cause I was told that forged pistons should be tight so they dont make noise when motor is cold but then i heard that they should have say .007 clearance cause they expand more than cast do....
I really dont know anymore, just dont wanna spend the money if I end up using the $800 pistons for ash trays when i dont eaven smoke...
Old 08-15-2005, 10:27 PM   #7
Venolias are .007". Best bet is to phone the vendor your getting the pistons from.
If you can remove .002 honing, then your a better man than I,
Old 08-15-2005, 10:40 PM   #8
ok thanks again simon...
I am getting a hone for a drill this weekend, so after I am done I will check everything out, post my clearance and find a piston to match ( I hope )
Old 08-16-2005, 08:36 AM   #9
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I think you better find someone who has some idea of what they're doing to hone the bores before you go and screw it up for yourself. Pay a machine shop / engine builder to do it.
Tim_K is offline
Old 08-16-2005, 09:05 AM   #10
agreed.
it would be a big headache to go through all that work and have a piston seize in the bore. plus its always a good idea to start with a fresh, clean bore/hone. and i recommend a tourqe plate. plus you can have some arp's installed in the rods while getting the bore/hone.
wiseco calls for .0035 clearance, which i believe is about the tightest forged piston clearance available.
mo' parts is offline
Old 08-16-2005, 01:01 PM   #11
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
Stephen, I agree with Adam & Tim, go see my machine shop "Harold's Automotive". I had my whole bottom end done there: Wiseco's, ARP Main Studs, ARP Wave Lok Rod Bolts, Shot Peened CB Rods, Turned Crank, Hot Tanking, etc etc. Motor runs HARD!
Good, honest, and fairly priced guys over there!
91DSX is offline
Old 08-16-2005, 05:08 PM   #12
Roger do you know what the part number was for the wiseco pistons that you have, and where you bought them from would be a help too.
Old 08-16-2005, 05:58 PM   #13
www.******************** carrys wiseco. mine were .020 over pistons
Old 08-16-2005, 06:12 PM   #14
Engine: SOHC 2.5L
+1
Yup got my 2.5L .040 over pistons from Chris W/TU too, awesome service and they come with everything you need, Stephen.
91DSX is offline
The eBay Song | Adverse Credit Remortgage | Cheap mobile phones | Fast Loans | Myspace Backgrounds
Page generated in 0.48223 seconds with 13 queries
