09-04-2005, 03:55 PM
Funky cylinder pressures - could use advice
My Ride: GLHS, Daytona & SC
Engine: All 2.2 Garretts
My SC has had water leaks ever since I bought it, now I've replaced all the pipework save the turbo lines around the back of the block, and it didn't lose any water. Anywho, it started running like crap and started using water, so I did a quick check with my basic compression tester, and got this:
#1--#2--#3--#4
75--162-148-145
Now #1 is obviously where the water is going in, but #2 is what I'm really worried about! Could that higher pressure be caused by a worn bearing causing the piston to come up higher than it should?
I'll be testing the S block this week, if it checks out ok I'll swap the engines whole as a temporary measure ... good excuse to get a common block
