09-04-2005, 06:06 PM
Use a sleeve or find a new block?
My Ride: 91 Spirit R/T
Engine: TIII
I picked up a rebuilt TIII engine from a local machine shop a while back. I was hoping to relube the bottom end and put in my R/T. Anyways there is a very sizeable gouge in one of the bores. Absoultely not useable like that. I can't complain, I got it for a song.
Would I be better off just getting the block sleeved or should I find a different common block and machine it for the TIII goodies I have? The pistons are already 1mm over. I'm hoping to be able to put down in the neighborhood of 425+WHP all said and done.
09-04-2005, 09:49 PM
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
Why don't you spend a few bucks & get it sonic tested. You can go a full 0.060" over on a solid block. This is a 3.50" bore. The only difference I'm aware of between the TIII block and the garden variety is the lack of provisions for a distributor (no hole).
Mike
09-04-2005, 10:21 PM
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Yeah, but he already has a set of .040 over pistons.. And you'd be ordering your own custom run of .060 pistons, that'd be awefully expensive..
09-04-2005, 10:53 PM
My Ride: 89 Shadow
Engine: 2.5 turbo
bore and sleeve might be the cheapest way. and a good way to add some more stregnth to it./
09-05-2005, 12:19 AM
Authorized TD Vendor
Sleeve it. Won't cost much, and won't hurt anything as long as you only need one. I did it on one of my cars. engine has 35,000 miles on it and still running strong.
later,
Cindy
FWD Performance… One stop no hassle shopping for your front wheel drive turbo car. Custom calibrations, T1,2,3,&,4. 2bar/3bar, 8v or 16v, including hybrids. Bank on over ten years of calibration R&D and thousands of street, track and daily drivers around the world. www.fwdperformance.com
Your FWDperformance Team
281-288-4411 or 281-642-3878
09-09-2005, 09:51 PM
Engine: TIII
Thanks for the info. I was uncertain of the strength of a sleeved cylinder.
09-10-2005, 12:57 AM
Find out how much it costs to sleeve it, then make your decision.
09-10-2005, 01:44 AM
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
remember: 1 sleeve at most. if you must have 2, they can NOT be adjacent to each other. ie: sleeving #1-2 or 2-3 or 3-4. block integrity would be compromised if this is done.
http://www.thedodgegarage.com/turbo_shortblock.html
i'm in the process of deciding to sleeve if i'm not able to find a decent block locally to use.
09-10-2005, 11:22 PM
Engine: TIII
Cost isn't too much different. Buy a core block-65; clean, deck, bore&hone, drill holes for oil drainback and PCV vent- 110-120 Figure a little over 200 for a finished block.
Sleeve, bore and hone cylinder- 185.
09-11-2005, 12:19 AM
My Ride: 89 Shadow
Engine: 2.5 turbo
well if you can get the block doen for tht chep i would go ahead and do that.
09-19-2005, 10:12 PM
#12
Engine: 2.5 TBI
the 'chiners charge 110 per sleeve. what's included is the sleeve itself and the labor; bore, press, bore and hone.
10-08-2005, 07:19 PM
#13
Engine: 2.5 TBI
well, luck has it that i did not need any sleeving at all. the .020 bore was able to clean out the cylinder. so if you're lucky you might not actually need any sleeving especially if you allready have oversized pistons. (assuming that the cylinder bores are standard sized.)
my worse case scenario was having 2 sleeves put in but nope. not a single one.  saved myself 220 bucks!
10-08-2005, 10:10 PM
#14
Originally Posted by bluneon
That is my old TII block.
All was OK until the 3rd sleeve was installed.
