Old 09-08-2005, 12:51 PM   #1
Getting the crank out?
ok i have my transmission out, my head off, and pistons and rods out, ok i took all the main caps off and my problem is i dont know how to get that little pulley on the end off, can somebody give me a clue on how to do it because i just cant figure it out. thanks
turboXE85 is offline
Old 09-08-2005, 12:58 PM   #2
Engine: 2.5 turbo
You need to use some kind of puller to get it off. They make a special one for it but I have used a steering wheel puller before. You may be able to rent one for free from autozone
slasky is offline
Old 09-08-2005, 01:10 PM   #3
ok cool thanks
Old 09-10-2005, 03:52 PM   #4
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
buy a bunch of different sized/threaded bolts that are long enough when using the puller. you'll have to use 3 at the minimum to thread into the sprocket and then pulll it out with the puller.
bluneon is offline
Old 09-10-2005, 08:53 PM   #5
My Ride: 87 Shelby Z
I drilled three holes in a piece of 3/8 flat stock to match up with the holes on the sprocket. Then I put a long bolt down the center that bottoms out on the crank. Then put the three bolts through the flat stock and into the sprocket. Tighten the three bolts evenly until the sprocket comes off.
Benji Farr
Green Bay WI
87 Shelby Z TII 15.2 @ 90.7
88 Shelby Z TI 2.2 auto
91 Shelby TI 2.5 5spd
http://bfarroo.tripod.com
http://www.extremepsi.org
bfarroo is offline
Personal Finance | MPAA | Bucay | Buy Anything On eBay | Mobile Phone
Page generated in 0.42717 seconds with 13 queries
