Old 09-11-2005, 08:19 PM   #1
sat for a couple months
My Ride: 1986 lancer ES
Engine: t1 135
ok i tore apart my lancer in the beginning of july,july 5th to be exact,and it has sat until now. Being that it has been two months of not having ran is there anything i need to do as far as possibly priming the oil pump or relubing rod bearings or any of that stuff to make sure i dont screw up an engine with only 15k or so miles on it
86lance is offline
Old 09-11-2005, 11:15 PM   #2
Engine: t1 135
weeeee here i go
86lance is offline
Old 09-12-2005, 07:56 AM   #3
Engine: t1 135
bump
86lance is offline
Old 09-12-2005, 06:10 PM   #4
Engine: t1 135
bump
86lance is offline
Old 09-12-2005, 08:29 PM   #5
My Ride: 1993 Iroc R/T
Engine: 16v DOHC 2.2 Turbo
Just slowly click starter over 5-6 times and I think you'll be set. If this car keeps sitting like this for months, you might want to think about putting Energy Release in your oil. ER will literally soak into the metal and really help lubricate, especially after months of not starting.
DaytonaFury is offline
Old 09-12-2005, 08:41 PM   #6
Engine: t1 135
how about rotating the engine over via a breaker bar or something
86lance is offline
Old 09-12-2005, 09:26 PM   #7
My Ride: 91 Spirit R/T
i would imagine anything to get the stuff re lubed so and rotations should do it
FTT843 is offline
Old 09-12-2005, 10:32 PM   #8
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
Disconnect the HEP and pull the plugs? And crank? No fire and no compression = easy cranking.
looneytuner is offline
Old 09-13-2005, 12:15 AM   #9
Engine: t1 135
sold
86lance is offline
Old 09-24-2005, 04:14 PM   #10
My Ride: 91 dodge shadow
Engine: 2.5 turbo
prime your engine just like you would if you were installing a new turbo, unhook the distributor spark plug wire and let her rip, the oil pump should circulate the oil without harming anything
rek4201 is offline
Credit Cards | Credit Cards | Online Dating | Bad Credit Loan | Mortgages
Page generated in 0.43270 seconds with 13 queries
