Old 09-12-2005, 07:40 PM   #1
2.0L Neon Pistons in a 2.2?
Engine: 135 CI
Can you use 2.0 Neon pistons in a 2.2 8V?
Mario_Boost is offline
Old 09-13-2005, 01:50 AM   #2
I would have to say no. The compression height is different and the valve pocket location and depth is also different. Diameter would be OK if honed to the 2.0L specs, but the rest is way off. You also have to take into consideration the difference in the 2.0L rod length, deck height and stroke.... again all different. It would be cheaper to just make a custom piston to match your set up.
-Mike
Mr P-body is offline
Old 09-13-2005, 02:26 AM   #3
Engine: 135 CI
Thanks a lot for your response. A friend of mine had some forged 2.0 pistons he was wanting to get rid of and he was practically wanted to give them to me, that's why I asked.
Old 09-13-2005, 02:27 AM   #4
mock_glh's Avatar
My Ride: '85 Omni
Engine: 2.5L
My 2.5L hybrid project has Neon 2.0 pistons and custom aluminum rods. The rods are the conversion part. They are the proper length and fit the .865 pins on the Neon pistons.
mock_glh is offline
Old 09-13-2005, 02:39 AM   #5
Are those pistons custom made? because the stock pin bore for a 2.0L is .827" and if so is there any other mods done to the ring lands or compression distance?
What length rod did you end up with?
Thanks,
-Mike
Pacotes Carnaval Salvador | Mortgage Calculator | Internet Advertising | Edinburgh Hotel | Mortgage
Page generated in 0.31746 seconds with 13 queries
