Old 09-15-2005, 02:19 PM   #1
Wrist pin sizes???
Ok, this always seems confusing to me.
I'm in the process of rebuilding a motor. I have FWDP recondition rods and stock .020 mahle pistons.
I was thinking of going with forqed pistons instead. Does this mean i need to have the rods resized for the wrist pin?
What set of forqed pistons comes with wrist pins that wouldn't require me to resize the rods?
later
daytonairoc is offline
Old 09-15-2005, 02:49 PM   #2
My Ride: 1991 Daytona Shelby
Engine: 2.5L
Just call a vendor, and order a set of pistons with the proper size pin.
Frank
Frank is offline
Old 09-15-2005, 03:19 PM   #3
That is
too easy
Frank
Old 09-15-2005, 10:09 PM   #4
My Ride: 87 Z
Engine: 2.2 (+.040)
My wiseco's are stock wristpin...
87shelbyt2 is offline
Old 09-15-2005, 11:58 PM   #5
Engine: 2.5L
Really, no matter what you do, you are going to do some kind of machining. I would go with the following pistons in either size.
http://********************/shop/prod...products_id=60
With the smaller wrist pin, you may just be able to hone out the bushing on the end of the rod. If you go with the larger wrist pin, just get redone bushings and push new ones in.
Frank
Frank is offline
Loans | Myspace Backgrounds | Synchronization fast and easy | Guitar Lessons | Loans
Page generated in 0.30352 seconds with 13 queries
