Old 03-01-2006, 04:43 PM   #1
timing
My Ride: 86' GLH Omni
Engine: 2.5 Turbo
how do i know what to set my timming at????? I havea 2.5L swapped into a omni, with 87 csx comp, and 3 bar map sensor, what should i set my timming at to run on 5 PSI for break in????
me_2_3_5 is offline
Old 03-07-2006, 12:54 AM   #2
My Ride: 87 GLHS & 73 Cuda
If you are just breaking in the engine, set the timing 10 degrees with the coolant sensor unplugged at an idle. Also, the grade of fuel makes a difference in choosing total timing after you break in the engine and start turning up the boost.
tvanlant is offline
Cheap mobile phones | Guitar Lessons | Loans | S65 AMG | Php Scripts
Page generated in 0.31325 seconds with 13 queries
