Old 03-08-2006, 09:51 PM   #1
a/f gauge ?
when adding wire tha a a/f gauge wire does it need to be anything special, or just the same size....
DaytonaConnection is offline
Old 03-08-2006, 11:11 PM   #2
Power wire from the gauge or the wire that connects to the O2 sensor?
It really doesnt matter all that much. It doesnt take much I Have 18AWG to my 02 sensor and 18gauge for power wire.
Make sure you connect the ground to either a very good ground or directly to the negative terminal for the most accurate measurements
-toddi
toddipoo is offline
Old 03-09-2006, 06:41 AM   #3
i just need to make the wires longer to go where i need them...
Old 03-09-2006, 08:57 AM   #4
I used 20 or 22 guage on mine. Make sure everything soldered where possible. I used inputs right from the logic module in my car to connect the 3 wires.
william is offline
Money | Debt Consolidation | Bad Credit Loans | Home Loan | Remortgages
Page generated in 0.25359 seconds with 13 queries
