Old 04-02-2006, 09:30 PM   #1
E85 fuel, how will this affect running our turbos
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
I heard today that E85 fuel is terrible for the motors in most cars, like running grass clippings in there. what does this mean for our turbo motors??
xtrempickup is offline
Old 04-02-2006, 11:46 PM   #2
the only issues are it eats rubber seals and has less energy in it than gasoline.
but it is alcohol afterall, so you could crank the boost higher before getting detonation
xrattiracer is offline
Old 04-03-2006, 12:38 AM   #3
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Yeah, it's like 110 octane.. May need a custom cal to take full advantage of it. Maybe TU will start offering E85 cals once they get their dyno installed..
Una is offline
Old 04-03-2006, 12:45 AM   #4
Feedback: (32)
It is not a plug and play type of fuel. You can't just put it in a gasoline engine.
tryingbe is offline
Old 04-03-2006, 06:36 AM   #5
My Ride: TIII R/T
Feedback: (10)
ok, so its not a substitute for the regular old racoon piss in the stations
Old 04-03-2006, 07:49 AM   #6
You can use it in place of gasoline but you have to tune for it. guys are making stupid power on this stuff.
wallace is offline
Old 04-03-2006, 04:38 PM   #7
Feedback: (32)
Unless your car doesn't use rubber hoses...
"M85 vehicles have a few problems... Number one among them is that M85 is highly corrosive! All the fuel system parts had to be rated for use with methanol and so was constructed with stainless steel! (The injectors are nickel plated internally) Also engine clearances were different and special engine oil was specified for use with M85 as well. Anything that could come in contact with methanol had to be tested and upgraded, even the valve guide seals are different! All methanol specific parts are tagged or painted green. "
http://www.thedodgegarage.com/na_efi_ffv.html
tryingbe is offline
Old 04-03-2006, 04:51 PM   #8
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
one page mentioned that the $12/qt oil that mopar used in the meth engines were nothing more than penzoil IIRC...
Stainless or FFV stuff can be had in the yards pretty simply, running this stuff shouldn't be too hard, just gotta make sure a few things are okay, mainly the gas tank I would think, and the fuel lines. How well would high pressure silicone hose handle alky? would it eat it or anything?
Phreakish is offline
Old 04-03-2006, 05:43 PM   #9
http://www.turbomustangs.com/smf/ind...?topic=47094.0
http://www.turbomustangs.com/smf/ind...?topic=57851.0
turbodave/neon is offline
Old 04-03-2006, 05:52 PM   #10
Tryingbe that is M85, we are talking about E85 very different!! You want to read this thread and all the links. E85 Ethanol.
Daniel Merrill
89acclaim is offline
Old 04-04-2006, 07:16 AM   #11
E85 makes mad powa. check out this link for some good information: http://www.turbomustangs.com/smf/ind...?topic=47094.0
wallace is offline
Bankruptcy | MPAA | Debt Consolidation | CreditCards | Consolidate Student Loans
Page generated in 0.46715 seconds with 13 queries
