04-14-2006, 07:02 PM
Air/Fuel guage issue.
Unusual car guy
My Ride: 89 CSX #91
I have a 89 (2.5 turbo, Garrett T2, intercooled, 12-13psi) minivan I just installed a sunpro A/f guage on. I connected the ground right to the battery, the power to the radio fuse, and the dimmer to the dash lap fuse. When I turn to key to just before tunring over the engine, it sits at ideal (right in the middle) and if I turn on my blinkers I can make it jump a bit. While running I seems to work well till I get into boost. At WOT or even at 5psi it will show rich for a sec then jump to the last bar on lean and it will stay there till a little while after I let off the gas, sometimes it even stops showing lights at all. I know I'm not lean the engine runs great and there are no signs of detonation. Any ideas on what the problem could be. I would say it is the ground, but with it connected right to the battery that doesn't seem likely. Thanks for your help.
