I just got my motor together, but i can't for the life of me get the damn thing to come outta the hole hot. It lags very bad and it take an actual count of 7~10 seconds (using the 1 thousand 1, 1 thousand 2, etc method) before it starts hitting boost.
1) timing: set at 12 degrees
2) fuel pressure: set at 50psi base, 42 psi with vacumm line attached (this is because at 55psi base it was pig rich, fouled out the plugs)
3) Cam (S-2 taft): Set in perfect alignment as both valves were shut tight for the #1 cyclinder before i installed the head
4) crank sprocket to distributor sprocket timing marks in congunction with the bell housing torque converter alignment mark at the "0" degree mark.
5) distributor/rotor: pointing at #1 plug wire, slot is dead parallel with motor
6) Plugs: NGK G-4
7) Wires: Magnacore (red)
8) cap/rotor: mopar
9) Hall effect sensor: brand new mopar
10)TURBO: T3/T4 HYBRID
11) MANIFOLD/THROTTLEBODY: ONE PIECE PORTED TO 52MM, BUT USING THE 46MM FOR NOW
12) EXHAUST MANI, SIZE: 3" SYSTEM FROM SWINGVALVE BACK, MANIFOLD PORTED STOCKER
13) FUEL RAIL AND INJECTORS: +40'S, RAIL IS STOCKER MODIFIED WITH AN-6 ENDS INTERNALS REMOVED
14) EXTERNAL AFPR FROM TU (1.1 RATIO) MOUNTED ON SHOCK TOWER WITH GUAGE
15) FUEL PUMP: 255LPH WALBRO
16) MOTOR: 2.5L .030 OVERBORE
17) PISTONS: VENOILA .030 FORGED
18) I/C: SMALL NPR
19) BOV: 1ST GEN MODDED WITH 15PSI PRESSURE SWITCH
20) HIGH RPM LIFTERS
21) MOPAR HEAD GASKET
22) HEAD IS A "G" HEAD PORTED WITH O/S VALVES
23) 3BAR MAP
24) EXTERNAL CUSTOM VACUMM BLOCK FROM FWDP
25) VACUMM ROUTING: SHOULD BE RIGHT ACCORDING TO PAUL VELLIKY'S SPEC SHEET
26) TRANS: A-413 CLIFF RAMSDELL BUILT, T-TRAC FULL POSI, MVB, REVERSE SHIFT, ETC.
27) SMEC (*89 lebaron): AHHH!! Here's were i think the problem lies....It's a custom cal from Paul Velliky and it was done very well i'm sure of that!! He's always had great cal's and my last cal that used the T2 garrett and +20's was great. HOWEVER,...there always is that chance that something may have gone wrong and it is why i'm so pissed as to why he won't call me so i can have him simply "RE-CHECK" the cal. Why would i think the cal ???/....well, for starters i can't get the damn thing to give me fault codes. I've tried the on-off-on-off-on cycle and no joy. By the last "ON" cycle, the light never comes on at all. I'll only see the check light on the first two cycles, after that.....NADA!!! I've even tried the "ON", wait until the check light went out, then cycle for the codes, but still no joy! It'll never trip a code as i've tried making it trip by uplugging this or that and, oh yes, it'll give a light, but when i cycle the system to flash codes......NO WAY JOSE. IT AIN'T HAPPENING
Now i've tried setting the timing at 14 and even 16 degrees as i was told the S-2 cams like to be higher in timing. Anyway, the initial setup produced a very bad overly rich condition. Car would stumble and sputter and pop, etc. while getting to boost. The timing was and is very "bouncy" while trying to align the marks on the bell housing/torque converter with the coolant sensor unplugged. One moment it'll be at 12* then it'll bounce as low as 8* or at the notch above 8*, as well as bouncing from the notch above 12* to as high as 14* ??? Very unstable!! Anyway, i was told to try gapping the new plugs (which i'm back to champions RN9YC plugs) to .020 instead of the stock gap. Well by golly miss molly, it worked to the point of not being rich. HOWEVER, it's still at it's original sympthoms from the start of this thread.....BAD LOW END TORQUE!!!
I'm at my wits end, i'm figuring if i go back to the stock *89 roller cam and +20's instead of the +40's, if i'd get my low end power back? Problem there is the cal was setup for the +40's and the Taft S-2 cam. So i may be screwed!!!
Anyone, out there help please.
