05-02-2006, 10:11 PM
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
If you're going to run a decent I/C, then yes, I think you should run the charge temp sensor. The casl are (typically) setup assuming 140* or so charge temperature. The sensor is sued to add fuel when the charge temp is cooler than that. So, you would theoretically run leaner without the sensor when the I/C is doing it's job. That said, the CTS can be "turned off", and the cal made richer to be safe.
Also, I've heard (but not yet seen myself) that the sensor doesn't actually track the charge temp very well. It seems to track the manifold surface temp instead. Again, not confirmed by me, just something I heard...
