Old 05-03-2006, 12:37 AM   #1
Injector pulse width quiz
Shadow's Avatar
My Ride: 86 S/C
Engine: 2.2 8V
Images: 6
88-93 TD stock electronics. List your top 5 reasons in the order you would attack them for low (13-14) injector pulse width. Base vehicle has great drivability, no codes, and the only clue that pointed you in the direction of inj PW was slightly lean o2 reading of .68 at WOT.
Robert Mclellan
[SIGPIC][/SIGPIC ]
Shadow is offline
Old 05-03-2006, 09:54 AM   #2
Shadow's Avatar
My Ride: 86 S/C
Engine: 2.2 8V
Images: 6
Cumon guys, you aren't getting graded on this! Give it your best shot there's no real right or wrong just diff oppinions. I think it would make for a good search item, lots of people have trouble with probs like this.
Robert Mclellan
[SIGPIC][/SIGPIC ]
Shadow is offline
Old 05-03-2006, 10:26 AM   #3
My Ride: 87 Shelby Charger
Engine: 2.2l 135CI
For starters, how can you verify your O2 reading?
O2 is great for a quick baseline, but the O2 is not necessarily the be all end answer to a fuel problem.
<M>
mw6886 is offline
Old 05-03-2006, 10:57 AM   #4
My Ride: 85 shelby charger
Engine: 2.2 liter I-4
Not sure I understand the question, you have found a lean condition by checking the O2 sensor output, and then checked the pulsewidth and found it to be low?
altered7151 is offline
Old 05-03-2006, 06:57 PM   #5
Shadow's Avatar
My Ride: 86 S/C
Engine: 2.2 8V
Images: 6
My bad, I've diagnosed a few TD's in the last 6 months that had some interesting reasons for having low injector pulse width. It's obviously not as hot a topic as I was thinking lol! You know, when you just get something in your head and it seems like a good idea at the time.
Robert Mclellan
[SIGPIC][/SIGPIC ]
Shadow is offline
Old 05-03-2006, 08:38 PM   #6
My Ride: 87 Shadow
Engine: 2.2L 16v Hybrid
do you have access to an oscilliscope? Check the pulsweidth directly in the circuit.
Check the wave of the ground control circuit, if there corners on the square wave are hashy... or the baseline PW ground is bouncy, check the grounds, as excessive resistance in either side of the circuit can cause insufficient ground exposure for desired PW.
cams1021 is offline
Debt Consolidation | Credit Cards | Internet Advertising | Loans | Bankruptcy
Page generated in 0.55387 seconds with 13 queries
