Old 05-06-2006, 04:43 PM   #1
O2 Sensor Question
My Ride: 89 turbo mini
I just noticed that my 89 turbo van that has had many mod to it before I got it has a 4 wire o2 sensor on it. Is this normal or is it aftermarket (maybe wideband)? also there are wire splices at the map sensor, I assumed the owner before me had a 3-bar map as he was allegedly running almost 30lbs of boost. I installed a 3-bar and fwdp stage 5 cal today and noticed that there are also 2 wires (brown and blue w/red tracer) spliced together by the map. Does anyone know what these might have been for?
Thanks,
Deric
turbovan89 is offline
Old 05-06-2006, 06:02 PM   #2
My Ride: No slicks Omni
The 4-wire o2 is stock, not wide band.
Repair any wires they have taped up by MAP, probably
tried bleeding voltage before going to 3-bar map. You
want a good solid,clean connection for the MAP.
russ jerome is offline
Bad Credit Mortgages | MPAA | Bankruptcy | Remortgages | Online Loans
Page generated in 0.30455 seconds with 13 queries
