05-08-2006, 05:23 PM
New setup questions.
Alrighty.. I've been patiently building my Omni over the winter and it's almost time to fire it up. Just so everybody knows, this is a '85 GLH running '87 Turbo-2 electronics w/ 1pc intake manifold and a stock T2 rad/IC assembly. These are the parts that the car is currently equipped with:
2.2L, pulled last summer from a 100k mi. New Yorker, works great
"G" head, fresh valve-job, milled 0.005"
Garrett T3 S60/0.63 w/ 2.5" SV
2.25" IC pipes, 1g DSM BOV
3" turbo-back exhaust
Stock fuel rail, stock T2 injectors, stock AFPR.
Now, my question pertains to fuel.. Since I'm running a 2-bar MP cal and stock fuel, with a turbo that's bigger than stock, not to mention the intercooler and exhaust, I'm guessing that I won't be able to run quite as much boost as I used to. What's the best way to figure out how much boost to run? I have an EGT gauge with the probe installed in one of the runners. Should I simply set it really low, then work my way up until I see EGT numbers ~1450*? This engine has cast pistons. Should I even try to use the stock T2 injectors with this setup?
Also.. Would it be worth it to upgrade to the 3-bar MAP/AFPR/Cal/+40's given the rest of the parts installed on the car?
Lets say I'm broke and +20's will have to do.. Can I simply install them w/o turning down the fuel pressure, or will an AFPR be neccesary?
Thanks!
