05-22-2006, 04:42 PM
Developed misfire at WOT
My Ride: '89 Daytona Shelby
This has me puzzled. 2.2 '89 T2 engine, no fault codes. Very good mechanical condition. Boost is graingered.
Stage 5 cal ... +40's, stock FPR. Autolites 63's or Champs 9Y's gapped .025"
Taylor Sprio core wires, new cap/rotor/distributor/HEP, Blaster 3 coil, 195* t-stat, CAI (front of car), MP+ turbo w/big exhaust housing, dual stock IC's.
Coolant checked ... 5W-30 Mobil 1 .. bigger radiator and oil cooler.
Was experiencing a random misfire at 20+ psi w/Champs while tuning. Gapped them down to about .027" and worked fine till about 23psi. Decided to swap in some Autolites for a change and gapped them to .027". Worked great to 25psi. Plugs look good, no detonation. Last couple days the engine started to misfire bigtime at WOT. ... like a uzi. Disconnected the battery to reset the adaptives and thinking it would start fresh.
Pulled plugs at gapped to .025" .... still misfiring, plugs look good. Figured I'd lower the boost today to try and find the threshold for this ... 18psi still produces a random misfire. Engine has plenty of fuel, even at 25psi. This isn't a lean condition.
Not sure what to look for beyond this. Not sure if gapping the plugs down further is going to eliminate this misfire. They were fine at .027" for a couple three weeks. If they were to get gapped down more .. how much farther is practical?
I'm thinking of swapping the stock coil back in here but want to see if any of you fellas have some other ideas first.
