Old 05-25-2006, 11:58 AM   #1
88 T1 into an 86 Dodge 600
Hey all !! wanna put an 1988 T1 engine from a LeBaron into our 1986 Dodge 600 (Orig 600 engine has a bad turbo and is worn out)
What is the easiest way to do this?
I have the SMEC and the wiring harness from the LeBaron.
Any help and advice much appreciated !!
kingsturbo is offline
Old 06-10-2006, 02:25 PM   #2
Still would appreciate some advice and ideas
Old 06-13-2006, 07:52 AM   #3
My Ride: 94 Ford Lightning
Engine: 351W v8
King, you should do some research in the electrical section on converting harnesses. It's a lot of work, and nobody has a fool proof guide out yet, but it is possible. Basically, you'll be taking the 50 pin bulkhead on the 88 harness and converting it to your 40 pin bulkhead connector on the 86 car.
Subliminal is offline
Car Insurance | Charity | Compare | Internet Advertising | Loans
Page generated in 0.42402 seconds with 13 queries
