Old 06-06-2006, 02:54 PM   #1
Question Cleaning fuel injectors????
My Ride: (2) 89 turbo caravan
Engine: turbo 2.5L
Is it possible to soak fuel injectors in lacquer thinners as long as i remove the O-rings? Or does this wreck them?
cook is offline
Old 06-11-2006, 03:27 PM   #2
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
I was thinking about getting 2 feet of fuel line, clamping it onto the outlet side of an injector, fill the hose with some type of cleaning solvent, and put about 30 psi of air pressure on it. Then have someone else touch 12 volts to the injector to open in. That should blast it out pretty good!
Not sure if that would wreck them or not.
Tim_K is offline
Mortgage | Credit Counseling | Online Loans | Bad Credit Mortgages | Personal Loans
Page generated in 0.31579 seconds with 13 queries
