Old 06-10-2006, 08:46 PM   #1
Question for Cal Guru's
My Ride: '89 Daytona Shelby
If I'm doing this right, I tune safe fuel pressure for WOT at 25psi boost. Works out to right around stock levels at idle ... maybe a bit less. (+40's, 3bar stg5, 255 pump)
The question I have is do the cal's fuel tables take care of fueling at cruise/off boost levels limiting the duty cycles enough for efficient MPG or does it just get close?
I was thinking of a way to make the fuel system a little more flexible, mechanically. Using a restrictor bypass in the fuel return line that would be boost activated. You'd set your WOT setting when in restrictor bypass. When not in boost the stock return line would be used lowering fuel pressure level. Restrictor size would determine the % of fuel pressure drop.
... or is this level of functionality not needed?
puppet is offline
Old 06-11-2006, 11:30 AM   #2
My Ride: 85 GLHT, 87 ShelbyZ
The cal should take care of it. You shouldn't have to touch the fuel pressure. If you are then the calibration is not Tuned right. With a proper cal you should have your stock fuel pressure reg on there. If it is too lean at wot and too rich at idle or the other way around then you need to have it re-calibrated.
GLHNSLHT2 is online now
Old 06-11-2006, 05:12 PM   #3
OK ... I don't know how the code works.
puppet is offline
Old 06-11-2006, 06:17 PM   #4
are you running D-cal or CHEM?
TurboBuggy is offline
Old 06-11-2006, 06:40 PM   #5
Feedback: (33)
Sounds like FWD cal.
tryingbe is offline
Old 06-11-2006, 07:04 PM   #6
Yep ... it's an aftermarket cal. This post is a result of my tinkering nature and complete lack of knowledge as to how versatile the fuel tables are within the ECU's code.
puppet is offline
Free Ringtones | Loans | Online Advertising | Compare | Advertising
Page generated in 0.28684 seconds with 13 queries
