Old 06-11-2006, 01:02 PM   #1
Talking Ignition Coil Recommendations?
My Ride: The UFO
Images: 10
Hi all,
I'm back to running 27-30psi of boost on my little 86 2.2 and have had to drop the spark gap pretty low on some random Chrysler Oil filled coil (rotor/pickup/wires are good, supply voltages are good). So I'm looking for your best recommendations of a powerful ignition coil which might let me keep a gap of ~1mm on the plugs, and yet one that doesn't cost $200. I'm a cheap TD guy.
Preferrably a part numbers or vendor links?
Thanks for your expert recommendations.
bn880 is offline
Old 06-11-2006, 08:49 PM   #2
My Ride: 85 Charger
Relocate a new (stock) or blaster coil close to the dist. This is the only reliable mod i'm aware of..
john1320 is offline
Old 06-12-2006, 05:22 PM   #3
My Ride: The UFO
Images: 10
Yes mine is relocated now, looking into a blaster. Thanks.
bn880 is offline
Old 06-14-2006, 01:00 AM   #4
My Ride: 86 SC & 98 Neon
1/4: 9.900
I use a blaster up to 32 PSI with a .28 gap.
However, don't forget there are actually two spark gaps. One on the plug and one in your distributor.
I bent the cable ends in the distributor so the are closer to the rotor. I also pinched the metal in the rotor so it comes out further. Just make sure they don't touch.
Carl
DblTrbl is offline
Old 06-14-2006, 11:07 AM   #5
My Ride: 88 Daytona Shelby Z
I like my crane fireball coil. Looks stock.
scott_s is offline
Old 06-23-2006, 12:55 AM   #6
My Ride: 85 Charger
P/N?
That sounds like the ticket for a stealthy approach!
john1320 is offline
Old 06-23-2006, 01:11 AM   #7
stay away from accel. Tried 2 accel's in my satellite, they both sucked, one even started leaking oil after about 6 months. In the trash it went, popped a junkyard stocker on and it's rumbling around better than ever!
DaytonaTurbo87 is offline
Old 06-23-2006, 01:14 AM   #8
hmm, not too sure. I can try to look it up for you. You may find it faster via a search on the Crane website.
scott_s is offline
Old 06-25-2006, 03:29 PM   #9
My Ride: Blue 94 SB RC Dakota
Engine: TBI 2.5
Ditto on the Accell they suck two have failed on me I just went back to stock.
Martin is offline
Old 06-25-2006, 03:51 PM   #10
My Ride: '89 Daytona Shelby
Had a blaster (3) poop out on me after a while at 25 psi. Got a recommendation from another member, DUGZSHELBY, on a coil he uses with good results:
http://store.summitracing.com/partde...5&autoview=sku
He uses a .5 ohm resistor to protect the SMEC driver because this coil has impedance of .7 ohm's.
puppet is online now
Old 06-25-2006, 07:09 PM   #11
The link to the one I mentioned
http://www.cranecams.com/index.php?s...&lvl=4&prt=162
A different one.
http://www.cranecams.com/index.php?s...&lvl=4&prt=164
scott_s is offline
Old 06-26-2006, 07:22 PM   #12
My Ride: 88 Shelby Z
How many volts does it take to jump a spark across that?
Sorry. Had to give a little jab over that 9/32" gap stated. I know you meant .028.
Stay away from Accel anything. I no longer know of any product they make that is worth buying. Years ago maybe, but not today. They have become a company of junk products propped up by an established name.
DartGTS340 is offline
Old 06-26-2006, 08:06 PM   #13
My Ride: 85 Charger
Thanks, scott
john1320 is offline
Old 06-26-2006, 08:58 PM   #14
My Ride: The UFO
Images: 10
No need for that here, I have spare power modules. (to be honest I doubt the extra load will burn the PM, it seems to gave a good tolerance) Now running a Blaster 2 at 27-30psi, it runs clearly better, especially up top. Compared to my old stock coil. My gap is still pretty small (0.75mm), going to try increasing it slowly.
bn880 is offline
Old 06-27-2006, 01:07 AM   #15
1/4: 9.900
Yep, those Blasters sure can jump the spark gap.
BTW, I also had an Accel drop dead on me after only 2 weeks of use.
Also, one more thing about making good spark... Most people are running a high performance fuel pump which draws more current. As it turns out, the pump and the + side of the coil both share the same puny wires. It's a good idea to seperate these two with their own wires so there will be less voltage drop to the coil.
DblTrbl is offline
Personal Car Finance | Credit Counseling | Debt Consolidation | Ringtones | Bankruptcy
Page generated in 0.83350 seconds with 13 queries
