Old 06-25-2006, 10:37 PM   #1
Is A/F ratio supposed to stay static at Idle?
This is pretty much the only wierd problem with my car.
'87 Lebaron, '88 T2 engine, '87 T2 computer.
At Idle, my a/f meter swings back and forth erratically from dead lean to the high side of stoich. Rarely goes to rich unless it's cold outside and the car has been sitting for a night.
My 3-wire O2 sensor is brand new when the engine went in (about 6 months ago).
With the mixture all over the place, I don't have a steady idle, and yet in gear, I get a (for the most part) steady idle. It only goes wonkey in neutral or park.
Where would I start with this??
TurboBaron is offline
Old 06-25-2006, 11:03 PM   #2
My Ride: '89 Daytona Shelby
The swing is normal.
puppet is offline
Old 06-25-2006, 11:56 PM   #3
speedyshelby16's Avatar
My Ride: Shelby Charger
Engine: 2.2 turbo II
Images: 8
+1 ^^ I got 2 td with af gauges both do it.
Check them out.
speedyshelby16 is offline
Old 06-26-2006, 07:02 AM   #4
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2L Turbo T-II
Mine moves around also with my wideband hooked up it moves around.
johnturbotron is offline
Old 06-26-2006, 08:33 PM   #5
Is the idle speed supposed to rise and fall with the lean/rich cycles?
Old 06-27-2006, 03:53 PM   #6
Engine: 2.2L Turbo I
Mine does, so I think that's normal also.
Dan
Edit: It does not move up and down a lot, just about 25-50 rpm or so.
22turbo is offline
Old 06-27-2006, 04:07 PM   #7
Mine swings approximately 500 rpm. I have a digital dash so I can't say for sure exactly but each "bar" on the tach equates to 250 rpm.
My engine will sway from 750 rpm to 1,250 rpm when in neutral or park.
Old 06-27-2006, 05:57 PM   #8
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
you need to clean out your TB and AIS real good with some carb cleaner. Fixed me up nice!
daytonajesse is offline
Old 06-27-2006, 05:58 PM   #9
My Ride: your mother
Feedback: (6)
check your sensors on the throttle body, it might even be time for a good cleaning!!
Juggy is offline
Old 06-28-2006, 12:08 AM   #10
TPS and AIS are both new, throttle body completely soaked and cleaned out about 6 months ago when the new engine was put together.
Today, It was only really cycling by about 250 rpm..... between 750-1000.
I may double check it with a proper tach to see what the acutal variation is. But if other people have the same deal going on I guess I have to live with it. I have a friend with a TBI Laser and he says his idle is all over the place and that the computer actually tries to change the timing at idle. We verified this with a timing light and his timing (and mine) does indeed jump around at idle.
*sigh*
Whoever said new cars are better needs his/her head examined. I don't have ANY issues like this with my '70 Inline-Six Gremlin.
Old 06-28-2006, 10:51 AM   #11
Jumping timing at idle with the CTS still connected is completely normal. This could be a hep issue.
Your other car doesnt have gremlins cuz it IS a gremlin, it's probably the reason your "new" car is having probs!
p.s. dont get it wet!
Old 06-28-2006, 03:42 PM   #12
LOL!
Old 07-01-2006, 08:05 PM   #13
My Ride: '89 plymouth voyager
My van does exactly the same thing you are describing, and the timing jumps around when I pull the CTS. I have no idea what's causing it, I will try the TB cleanout though.
tkelly27 is offline
Old 07-07-2006, 02:12 PM   #14
Idle fluctuating 250 rpm is not normal, especially on a relatively stock setup like you have. The AF "swinging" is normal at idle, but there shouldn't be fluctuations of the idle that go with it. What is your ignition timing set to? How is your idle vacuum?
I guess you could "live with it", but I wouldn't.
william is offline
Old 07-07-2006, 02:19 PM   #15
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Loose shutter assembly inside the distributor. Pop the cap, rotor and HEP out.. See if you can wiggle the metal shutter wheel independently of the center hub.. Pretty common for those to come loose a bit.
Una is offline
Mortgage Calculator | Credit Card Consolidation | Credit Card | New York Hotels | Bikini Models
Page generated in 0.49360 seconds with 13 queries
