Old 07-06-2006, 12:20 AM   #1
SBEC, adding charge temp sensor
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
What pin on the SBEC connector is the charge temp sensor? I have the pinout for a 2.5 turbo SBEC.. Doesn't list it as it wasn't used.. I'll be using a VNT cal, so I need to add that pin to my SBEC connector..
Una is offline
Old 07-06-2006, 09:31 AM   #2
How hard is it to add the pins to the connector? I need to do this for my sbec too.
wallace is offline
Old 07-06-2006, 09:41 AM   #3
I searched and everyone seems to agree that it is still pin 21 for the sbec.
wallace is offline
Old 07-06-2006, 09:52 AM   #4
Una
Engine: 2.5L Turbo
Pretty easy to add them, flip the connector over, pull out the red retainers with something like a pick tool, then insert a new pin from the top till it clicks in. Old TBI connectors are good sources of new pins.. Sometimes the hole you want will need to be drilled out on top, the factory usually leaves the unused holes closed off.
Una is offline
Hotel Las Vegas | Indiana Flags | Car Insurance | Personal Car Finance | Mortgages
Page generated in 0.24017 seconds with 13 queries
