Old 07-10-2006, 12:55 AM   #1
td logic module woes! help me out experts!
alright so after getting my car running again after a cracked head (87 csx) i was having problems with weak erratic spark. changed hep coil etc. to no avail switched computers over and it was happy for awhile then would die. the only change i have made to the car is a one piece manifold with the stock vnt injectors. i switched the stock 2 piece harness over to the 1 piece intake. well noticing that both computers reek of burnt electrical i opened them up and found the diode connected to terminal #7 of the blue connector on the logic module was fried on both lcms.this is listed as power ground source thru fuel rail bolt. what could cause this? i have the ground that #7 goes to grounded thru the fuel rail bolt. and a ground from the back of the intake to the fire wall? not a good enough ground or what? HELP!! i need to know what happened before i can replace the lm.
turboaddict is offline
Old 07-10-2006, 11:09 PM   #2
not a good sign that no one has responded i take it?
Old 07-11-2006, 12:10 PM   #3
My Ride: 85 shelby charger
Engine: 2.2 liter I-4
Bump! C'mon someone out there has to know how to help, what would cause a diode to smoke like that?
altered7151 is offline
Credit Cards | Ringtones | MPAA | MPAA | Project cars
Page generated in 0.40820 seconds with 13 queries
