Old 07-16-2006, 06:13 PM   #1
Question does it really make a difference with...
My Ride: 89 Daytona Shelby!
Engine: Turbo II
i am curious, does it really make an big difference between the 8mm and 8.5mm magnecore spark plug wires? the only difference i can justify is the the price.
parker87 is offline
Old 07-16-2006, 10:21 PM   #2
Bigger is better in this case.
Old 07-17-2006, 12:04 AM   #3
My Ride: 88 daytona pacifica
Engine: 2.2, t3/t4 fmic
as you raise the boost yes it will help same as a stronger coil, but if you arn't running much over 10psi the smaller will do
88jbody is offline
Old 07-17-2006, 12:09 AM   #4
Engine: Turbo II
ok i plan to run at least 15psi, so thanks for the vital information
parker87 is offline
Old 07-17-2006, 06:52 AM   #5
My Ride: '89 Daytona Shelby
I run 25psi w/8mm plug wires. Don't see a problem with them.
puppet is offline
Loans | Advertising | Free Myspace Layouts | Mortgage | Best Credit Cards
Page generated in 0.31093 seconds with 13 queries
