Old 07-18-2006, 09:45 PM   #1
do you think i will need more fuel?
My Ride: 89 Daytona Shelby!
Engine: Turbo II
ok, i have 91 dodge spirit that is being converted to t2 status, will i need more fuel when install these: ported and polished head, intake, and exhuast, t3 turbo2 turbo(upgrade from mitsu), intercooler, .63 ar turbine housing, atleast 2.5 full exhuast w/ high flow cat and muff, and should i add anything that is essenstial for this combo? dont want
parker87 is offline
Old 07-19-2006, 12:06 AM   #2
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
depends how high you wnt to push it....if your really want to take advantage of those parts you should probly get the walbro 255 fuel pump, AFPR, and +40 injectors
what are your HP goal, is the car a DD or race nor what?
RPMurph is offline
Old 07-19-2006, 01:08 AM   #3
My Ride: '89 plymouth voyager
At stock boost levels, no your current fuel system is fine. At the higher boost levels your engine will be capeable of, yes definately need more fuel. Don't forget a recal murph!
tkelly27 is offline
Old 07-19-2006, 10:15 PM   #4
Engine: Turbo II
well i would llike 250 to 300 ponies also would be my daily driver/take it to the strip every once and a while.
parker87 is offline
Old 07-20-2006, 02:32 AM   #5
i would also like to know, i have almost exactly the same setup + 2pc intake +ported exhaust mani + 3" mandrel bent exhaust + custom 3" swing valve + wallbro 255
im only running 10lbs right now, once i get a new clutch in i would like to go to 14lbs
let me know what ya thing guys!
phaxtris is offline
Old 07-20-2006, 08:13 AM   #6
Feedback: (32)
Yes, you'll need more fuel if you go over 14psi.
tryingbe is offline
Forex | Remortgages | Credit Card | Personal Loans | Internet Advertising
Page generated in 0.47211 seconds with 13 queries
