Old 07-19-2006, 08:44 AM   #1
Can I get replacement injector caps?
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
I just pulled a couple sets of injectors out of engines to use in getting a newer engine running, and several injectors on each set had missing or broken injector caps. They snap over the spraying end and hold the rubber lower gasket in place.
And after they pop off once, they're so old, hard, and brittle that they split when being pushed back on.
Can replacements of these be found anywhere, maybe through a Chrysler dealer?
Tim_K is offline
Old 07-19-2006, 09:02 AM   #2
My Ride: 1993 Dakota
Engine: 3.9
I got them from NAPA several years ago. Like $3.00 per injector for caps and o rings.
ACR Turtle is offline
Personal Finance | Free Insurance Quotes | Credit Counseling | Web Advertising | Mortgage Calculator
Page generated in 0.34268 seconds with 13 queries
