Old 08-30-2006, 06:11 PM   #1
99% Throttle pulls harder than 100% WOT
My Ride: '89 Daytona Shelby
What would cause this action?
Foot to the floor ... engine pulls good. A bit loud (throaty) .. a bit choppy.
Back off pedal ... and I mean just a fraction and the difference is night and day ... smooth and real strong.
No codes.
puppet is offline
Old 08-30-2006, 06:53 PM   #2
My Ride: 99 Cummins
Engine: 5.9
Images: 6
my only logical explanation
WOT engine uses max fuel, ignores some sesnors. (o2 specifically)
not WOT it doesnt, and actually provides the best mixture..
maybe someone else can be more technical than me.
Timmay2 is offline
Old 08-30-2006, 06:59 PM   #3
My Ride: 1993 Dakota
Engine: 3.9
Sounds like it "may" be too rich. Or it could be too lean. Is it detonating?
ACR Turtle is offline
Old 08-30-2006, 07:13 PM   #4
I'm right on the edge of goodness. 20psi boost ... 2lbs less fuel or 1* more ignition and I'd be knockin'. This isn't like half throttle or even three quarter throttle ... just a slight easing up off the firewall type thing. Wierd.
It is rich in the idle tables ... stumbles a bit on tip in. Maybe at WOT the ECU is pig rich too? Even just a slight throttle position south of WOT brings in another fuel table/map? Hmmm ..
puppet is offline
Old 08-30-2006, 08:12 PM   #5
My Ride: 88 daytona pacifica
Engine: 2.2, t3/t4 fmic
put a bolt up through the floor and adjust it to where it pulls best then it still seems like you are flooring it. LOL
88jbody is offline
Old 08-30-2006, 09:11 PM   #6
hehehe ... don't think I haven't thought about that ... heh.
puppet is offline
Old 08-30-2006, 09:57 PM   #7
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
Well, at part throttle, the ECU is trying to get as close to 14.7 A/F as possible. If that's the A/F you think you want to run at 20psi boost, then by all means keep doing the part throttle dance.
12:1 A/F is safer for a turbo car under full boost.
14.7:1 @ 20psi boost makes cool ashtrays...
Shel-Game is offline
Old 08-30-2006, 10:04 PM   #8
Rob ... is anything less than to the floor considered part throttle?
I'm not seeing 14.7:1 at a touch off WOT ... am I? ... at least my O2 readout says otherwise.
puppet is offline
Old 08-31-2006, 02:13 AM   #9
My car does that too. Half throttle feels twice as fast as full throttle, and I will get full boost.
Pretty lean though.
f3likx is offline
Old 08-31-2006, 07:56 AM   #10
Engine: 2.5L T1
No, It's like 3.6v over min throttle volts. You can measure the output voltage with the throttle closed, add 3.6v, and that's where the computer thinks it's at WOT.
As long as your A/F is safe, you should be OK. You want to be 0.8v or more on a n A/F. That's about as accurate as you can get without a WB.
Old 08-31-2006, 10:45 AM   #11
I'm going to double check what I'm seeing today and check that sensor voltage as well. I'm just not clear on what would cause that big of a difference in such a small change in throttle angle position. I could understand this better if at full stop throttle the cal started reading another fuel/spark map. If not ... then I don't get it, unless it's a sensor glitch.
puppet is offline
Old 08-31-2006, 11:00 AM   #12
Engine: 2.5L T1
It DOES read different spark and fuel tables at WOT vs. part throttle. Part throttle tables are leaner and have more advance. That's whay it picks up power at slightly less than full throttle.
Plus, part throttle uses the O2 sensor for feedback and adjusts to try to get to 14.7 A/F. At WOT, it ignores the O2.
Old 09-04-2006, 08:03 PM   #13
My Ride: 86 GLH-T 2.5 W/A568
Engine: 2.5 T3T4 hybrid
My buddie almost killed my minivan engine on 95% throttle, granted, I am on a 90 SBEC, so it may be different, but it IS on a different set of tables. . . .So to speak. Man, I wan tto reply so badly, but cant really put what I want to tell ya into a comprehendable paragraph.
Basically, you go to WOT tables, ignoring certain sensors, at whatever it is below the changeover, you go back to adaptive fuel and timing curves. Now, on my mini, its so strong at WOT tables it was I assume less noticable that your situation, but I sure as hell noticed it, I was somewhat pissed at first, till I read the data, timing getting yanked, knocks galore, and speckled slug tops.
If you are a Dcal guy, run some data at 95% ans 100%. Re write your fuel and timing curves to closer resemble the 95% values. Lots of time and work, but O so worth it with the new found power and fuel econ to boot.
TheGinMill is offline
Old 09-04-2006, 09:17 PM   #14
Thanks for the insight TheGinMill.
puppet is offline
Old 09-05-2006, 08:59 AM   #15
My Ride: 87 GLHS
Engine: 2.2 8Valve
Could a 3.5v diode be used to keep the computer from thinking it is @ wot? And then set things correctly from there. Or maybe have a cal set up with the wot throttle value changed to a voltage to high for the tps to achieve. Just throwing out some ideas.
Brian Putman is offline
Online Loans | MPAA | Online Loans | US Business Directory | Credit Cards
Page generated in 0.50443 seconds with 13 queries
