Old 09-04-2006, 03:31 PM   #1
bad idle with a/c on
My Ride: 89 daytona
Engine: 2.5 bored .40 over
i have a 89 dayotna n/a how do set the idle on it ??? when the car is runing with out the a/c it is fine i turn the air on and it wants to idle ruff and shake a bit more the car runs ok but this i can not figure out... what can i adjust to get rid of this issue...
KRAZZYKID28 is offline
Old 09-09-2006, 11:05 AM   #2
sounds like you may have a voltage issue...get your alternator checked!
85OMNI is offline
Old 09-09-2006, 12:08 PM   #3
i would make sure the ais motor is operating correctly. the ecu maintains idle normally, but cannot compensate enough if the ais is non-functioning.
xrattiracer is offline
Old 09-11-2006, 07:53 PM   #4
My Ride: 89 daytona
cool i changed the altenator out and it now has 13.31 at idle befoer it would not hit 13 volts goin down the road at 2500 rpm
Debt Consolidation | Advertising | Verizon Ringtones | Mobile Phone | WoW Gold
Page generated in 0.49156 seconds with 13 queries
