Old 09-07-2006, 06:45 PM   #1
beetle swap.....
My Ride: v8 914 porsche
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
hi guys....im in the process of building a 73 vw beetle with a dodge 2.2 turbo 1 from an 86 lebarron....
here my problem, im buying it all piece by piece....and i wont have another car to look at to wire it up.....
do any of you know where i can get a really good ecu wire diagram?
thanks
ball_zach is offline
Old 09-07-2006, 08:08 PM   #2
My Ride: 73 AMC Gremlin
Engine: 304ci V8
that sounds like a sweet project, wish i could help you but i cant. i would like to see some pics and want to know how this turns out! your the only person ive seen do this swap
sleeperspirit is offline
Old 09-08-2006, 12:33 AM   #3
if you change over to a 88 or 89 smec setup, i have all those wiring diagrams online.
xrattiracer is offline
Old 09-08-2006, 03:26 AM   #4
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
i was trying to stay away from the later model stuff because ill have no good place or an intercooler......plus i use to own a turbo 1 lebarron way back......and i was really impressed with that car.......now that engine on a 1600lbs beetle should be something else.
Old 09-08-2006, 03:35 AM   #5
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
once i get the ball really rolling on this ill set up a web sit for the car.
Old 09-08-2006, 08:22 AM   #6
how you gonna run the radiator?
XxhorizonxX is offline
Old 09-08-2006, 09:04 AM   #7
My Ride: 88 sundance
your best bet would be use 88 t1 wiring, those didnt have an interccoler and were 2.2. 89's were 2.5 so the smec would be different and a 89 2.2 t2 would be calibrated for a intercooler. Or use 88 or 89 wiring and get someone to do a custom cal for your setup. 87 and below wiring sucks cause you have a seperate power module and logic module, 88 and 89 combined them into one unit called a smec
jdawg is offline
Old 09-08-2006, 10:36 AM   #8
yep, the only real difference is in the cal. can choose to use an intercooled one or not .you really want an ic if you can find room for one tho, it is sooo worth it. for limited space setups, consider an air/water core. they are ideal in this situation because you can use a fairly small intercooler core, and run hoses to a heat exchanger (small radiator) in a place with more airflow. in your case its especially suitable, since you could put the heat exchanger in the front.
Old 09-08-2006, 10:58 AM   #9
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
this is all really great info guys....i never thought of the air water cooler...i may have to fab one up......and i have chosien to go with the 88 TI set up....i went to the junk yard today and took a bunck of photos of the engine and wires and such.....this is going to be a killer project...
Old 09-08-2006, 11:05 AM   #10
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
i have been thinking about the intercooler thing......for my purpose i dont think i shoud use one.....im trying to keep the engine aroud 150hp.....because the stock beetle tranny will probably have a hard enought time holding that.....if i had gobs of cash id love to get a 300+ hp 2.2 and a porsche 915 transaxle....but im poor...lol....and i wanna do this from start to finish for car and all for less then 3k.
Old 09-08-2006, 11:15 AM   #11
a vw trans bolts to the 2.2 engine?
jdawg is offline
Old 09-08-2006, 01:18 PM   #12
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
no.....a place makes an adapter plate http://www.kennedyeng.com its a kit that comes with a new flywheel and modified pilot bearing and clutch pressure plate...ect
Old 09-09-2006, 06:13 PM   #13
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
This'll place the engine behind the rear wheels or are you going to flip the tranny?
Avenger is offline
Old 09-09-2006, 08:37 PM   #14
flip it? upside down? the front pump, valve body would get really messed up.
jdawg is offline
Old 09-10-2006, 02:22 AM   #15
Engine: 327 chevy
Induct: Nitrous
1/4: 12.100
nah....engine will be in the rear.......i thought about using a 914 transaxle and making it mid engine.....but that would turn the bug into a whole different project.....plus i want back seats.
Song Lyrics | Mortgages | Credit Cards | Repair Bad Credit | Secured Loans
Page generated in 0.66240 seconds with 13 queries
