Old 09-08-2006, 11:52 PM   #1
782 head milled .017 problems
just got my head milled .007, and it was previously .010. is .017 enough to even notice? i have a 89 cb with glhs maping, stock cooler and it hasnt ran good enough long enough to play with the boost. i didnt plan on running more than 18-20 lbs. is milling the head enough to notice any thing on the top end, maybe due to retarded cam timing? i dont think that ill have a problem, but im better at assembly than avoiding reassembly.
grand rapids is offline
Old 09-09-2006, 05:36 AM   #2
My Ride: 1986 laser xt t-tops
Engine: turbo 153
yes but not a lot @.017 but some times it will make the belt walk on the cam gear
turbo xtc is offline
Old 09-09-2006, 07:36 PM   #3
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
walking on the cam gear=improper tention
RPMurph is offline
Old 09-09-2006, 10:40 PM   #4
It could make a difference but the MP gasket is thicker than stock so it will help take up some of the metal removed.
Old 09-10-2006, 04:34 PM   #5
My Ride: 86 Lazer-89T2 power
Engine: 89 2.5 T2 built
Felpro makes a .020 copper head shim, I recently bought one. $18. had to order it, took 2 days from Auto Zone. Better safe than sorry.
ButchSuppe is offline
Old 09-10-2006, 08:04 PM   #6
i talked with cindy and she said they make different thickness mls headgaskets, but they are int the 100$ range, way too much for a cheap bastard like me. when i asked the machinist if they just throw it on the belt sander, he gave me a look and said "belt sander" is a dirty word. so being the surface was milled parrallel with the cam centerline, i dont see how belt walk is posible, but maybe thats a side effect of "belt sanding". i was more concerned with tuning with higher boost, like .010 of milling is worth 2 lbs boost or something like that. i like it better when you guys do my r&d.
Old 09-10-2006, 09:52 PM   #7
You don't belt sander heads. If the timing belt walks, its too loose or too tight, can't remember which one.
.010 is nothing.
Old 09-10-2006, 11:00 PM   #8
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
I had a problem of the timing belt riding the inside edge and rubbing. Everyone kept telling me I had a belt tension issue.
Nickel loose or million dollar tight, it changed nothing as to how the belt ran. The problem was a bad belt. A new Mopar one saved the day. Even with the new belt, tight or loose doesn't change where the belt rides one little bit.
Thats just my experience. I've done lots of timing belts on lots of engines and never had a walking issue. I never used a tension guage to this day.
phantomrt is offline
Credit Counseling | Loans | Buy Anything On eBay | Bankruptcy | Credit Cards
Page generated in 0.33074 seconds with 13 queries
