Old 09-10-2006, 01:45 PM   #1
MAP vac line to Intake Manifold
My Ride: 1985 Omni GLH Turbo
Engine: 2.2L I4
Images: 4
On an 85 Omni GLHT (Stock)
I'm redoing the vac lines right now, and I'm wondering if I should keep the map sensor vac line connected to the solenoid, or will it cause problems to run the vac line from the map directly to the intake manifold?
farazshah is offline
Old 09-10-2006, 04:27 PM   #2
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
the MAP is connected to the solenoid so that the computer can occasionaly engage the solenoid and use the MAP to reference outside air pressure to use that as a baseline
you need to leave it connected; I suggest hose clamping each and every vacuum line to prevent them from popping off under boost at in-opportune moments... DAMHIK
detobias is offline
Lockers | Xecuter 3 Mod Chip | Advertising | Bankruptcy | Debt Consolidation
Page generated in 0.31866 seconds with 13 queries
