Old 10-04-2006, 12:21 AM   #1
3.0L Hop up - injector opinions
My Ride: 1994 Caravan turbo!
Images: 4
95 Voyager 3.0 5 speed manual.
Supercharger project in progress as indicated by my other threads. I hear Mustang 5.0 Injectors are a good step up. I'm not sure what the flow rate is, but I'm only going to run 9lbs of boost, max.
Suggestions?
big_P is offline
Old 10-08-2006, 05:34 AM   #2
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
ford high impedence injectors 30-40lbs, but make sure you have an AFPR and a gauge.
DustyR/T is offline
Old 10-08-2006, 12:13 PM   #3
Images: 4
Yes, I have a RRR and I can use the gauge we have at work to fine tune things. Which Ford injectors are High impedance and 30-40lbs?
big_P is offline
Old 10-11-2006, 07:24 AM   #4
My Ride: 88 c1500 Lowrider
Engine: 305
Feedback: (7)
I believe i read somewhere that T2 turbo injectors will work, just have to find 6 of em'
just my 2 cents
shadetreeshop is offline
Old 10-11-2006, 11:41 AM   #5
Images: 4
Can anyone verify that?
big_P is offline
Old 11-16-2008, 09:11 PM   #6
Re: 3.0L Hop up - injector opinions
My Ride: '90 Dodge Daytona
I'm pretty sure that I heard T2 injectors will work too. But I'm wondering if 3.0's wouldn't be able to use Stealth injectors too. I'm not sure if stock 3.0 injectors are low or high impedance or what we would need to do if they were one or the other.
alangentry07 is offline
Old 11-16-2008, 09:41 PM   #7
My Ride: 93 plymoth sundance
Engine: 3.0 3g72
if i remember correctlly pre 90 was low imp. and turbo 2 injectors can work or after 90 high which then ford injectiors will work
paduster is offline
Old 11-17-2008, 12:30 PM   #8
Authorized TD Vendor
They look like a lower flow rate version of the same injectors used on the 2.2 and 2.5, so there's a good chance the turbo motor (or any Bosch EV1 style injector) will physically fit. The Stealth turbo motor appears to use a different style injector though, probably Nippondenso.
Matt Cramer - Turbocharged '66 Dart
DIYAutoTune.com
Matt Cramer is offline
Ringtones | Pacotes Porto Seguro | Debt Consolidation | MPAA | Adverse Credit Remortgage
Page generated in 0.35400 seconds with 13 queries
