Old 10-07-2006, 02:03 PM   #1
will daytona gas tank fit lebaron?
Anybody know if an 89 daytona gas tank is the same as an 89 lebaron gas tank?
glh1985 is offline
Old 10-14-2006, 06:42 PM   #2
My Ride: 87 Pacifica
Engine: 2.2l T1, modded soon
Ya know GLH, I would have to assume they are, but I cannot be sure. They do have the same underpinnings, same brakes, same motor/tranny, radiator, wiring, etc. I believe the only difference between the 2 is the skin. As long as it is from the same generation model you shouldnt have an issue.
erikstrieter is offline
Old 10-14-2006, 07:20 PM   #3
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
I do not know for sure, but I am going to say no because the floor pans are different behind the front seats.
phantomrt is offline
Old 10-23-2006, 11:16 PM   #4
My Ride: '88 Lebaron
Engine: 2.5 T2
Exactly the same. I have a Daytona tank in my Lebaron and a Lebaron tank in my Daytona - it's a long story - but yes they are the same.
nomadman2001 is offline
Old 10-23-2006, 11:17 PM   #5
Engine: 2.5 T2
and the Lebaron tank is from a 1995 and it's in a 1989 Daytona.
Old 10-24-2006, 04:17 AM   #6
Like I said GLH, I wouldn't try putting an 86 tank on a 92, they are a different generation car, but I believe the 89's will swap.
Old 10-25-2006, 08:34 AM   #7
Fuel tanks
My Ride: All of them
Engine: 2.1 T1
You can check one of the online autoparts stores and compare part #s. I checked 89 LeBaron and Daytona tanks on Advance Autoparts website. The same part #.
mike mckay is offline
Old 10-25-2006, 05:34 PM   #8
Engine: 2.5 T2
Good point Mike! I use them for reference all the time.
Old 11-01-2006, 02:20 AM   #9
The gas tank in my 1988 daytona is out of a early nineties dodge dynasty. didnt even mess with the pump just wired it up . had to splice different plug for pump, and use some rubber fuel hose.. but i am pretty sure a lebaron tank will fit.
packrat_turbo is offline
Pink Ranger | Mortgage | Debt Consolidation | Loans | Mortgages
Page generated in 0.52749 seconds with 13 queries
