10-16-2006, 12:07 AM
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I had a helluva time last year with the same problem on my Shelby Lancer. It would always die out at 1/4 tank and I could only fit about 11 gallons in when it started sputtering out. I had installed a new aftermarket fuel tank and was convinced it was because of the slosh bowl design wasn't keeping the pickup covered with fuel as well as the OEM tank. Then after tearing it apart, I discovered that I hadn't installed the pump down into the sending unit enough and the pump inlet wasn't connecting to the pickup sock thingy which snaps on with an o-ring seal. So when the gas ran low, the pump would suck in air, bypassing the pickup sock. Hope this helps.
Also make sure the pump assembly is 'clocked' correctly so the pickup screen maxi-pad looking thing rests flat on the bottom. If you get an aftermarket tank, you might also have to sligtly bend the fuel level indicator arm so that it doesn't get hung up on the edges of the slosh bowl like mine did.
